how can I reduce the file size of transient data
Old   November 1, 2000, 05:42
Default how can I reduce the file size of transient data
Yuan-Heng Huang
Everytime,when I run transient case the *.pstt file is so big.It's size is 2GB .And the Star windows would stop with the massage,"system error".
May I save the data with several cells during the STAR Analysis running prrcess?
thanks for you answer!!!
hyh 2000.11.1
Old   November 1, 2000, 07:09
Default Re: how can I reduce the file size of transient da
A.Hassaneen
The best way to reduce the size is to choose the POST frequency (in the SOLUTION CONTROL) to be every 5 or 10 time steps.
Old   November 1, 2000, 09:56
Joern Beilke
Save only those data which you need for postprocessing. Maybe you have to define several "load steps". Another option is to do use "posdat.f" to extract what you want after each time step.
Old   December 1, 2000, 22:16
Mathew C. Mathew
I am facing a similar problem, I actually require a high resolution of results, and so wish to collect data for small time steps. I was under the impression that using the transient module, I would be able to select the cells which I want the post transient data stored for a load step. However, even when I specify a range, the data collected for any step is infact of all the cells in the mesh, not just the selected few.
The major problem seems to be with the inclusion of mass flux (U,V,W and mass flux are what I am interested in and only store U,V,W, and flux)
Infact even when I store the data infrequently, the pstt file becomes large very quickly. I have 197,190 cells, and after saving for 5 steps I accumulate a pstt file of 67.7Mb (I am hoping to get about 720 time steps saved.......still hoping and trying)
If anyone has come across this before, I would be very grateful for any ideas,
thankyou, Mathew
Reduce size of Ansys.rst file in FSI simulations? Jorn CFX 6 September 21, 2017 03:00
Error 28 Transient data file is not connected wei Siemens 6 November 19, 2008 12:32
transient data file in les computations eos Siemens 0 March 23, 2006 08:51
file-size in transient calculations John FLUENT 1 February 12, 2001 15:13
Reduce output file size!! Jonac CFX 1 September 15, 2000 03:24
