COMANDS TO EXPORT GAMBIT MESH IN PROSTAR3100A
Old   February 8, 2001, 06:50
Default COMANDS TO EXPORT GAMBIT MESH IN PROSTAR3100A
Cerioni
I'd like to know the best exportation format file for Gambit and the correct comands to import it!
Old   February 8, 2001, 16:57
Default Re: COMANDS TO EXPORT GAMBIT MESH IN PROSTAR3100A
Chinor
Read the Gambit neutral file or mesh file into Tgrid.
From Tgrid, write out a Patran file.
Import the Patran file into Prostar.
Chinor
Old   February 9, 2001, 03:56
Cerioni
What's this "Tgrid" ,is it acomand of Gambit? Sorry for the stupid question but I'm a beginner! However thankyou Chinor
Old   February 9, 2001, 14:38
Chinor
Tgrid is another pre-processor for Fluent.
You should check with your software custodian to see if you have this piece of software.
Chinor
Old   February 12, 2001, 12:44
hvn
Save your gambit mesh in neutral and in star-cd, in the command line, type the command : gambit nameofyourmesh.neu
Old   February 13, 2001, 12:58
Chinor
hvn
I tried that and Prostar (v3100a) crashed.
Did you actually do this successfully?
Chinor
Old   February 15, 2001, 05:05
Cerioni
with 3100A cruched, with 3100 didn't cruch but it isn't successful!
Old   February 20, 2001, 12:08
hvn
I used this command with prostar v3100 and there was no problem. The mesh in prostar was identically as in fluent 5 and in Gambit
export mesh to GAMBIT manu FLUENT 8 April 8, 2008 16:21
Gambit mesh export Satya Main CFD Forum 1 May 26, 2004 17:06
gambit export 2d mesh SHANKAR FLUENT 3 April 25, 2004 23:47
Export mesh back to Gambit Paul FLUENT 3 March 30, 2003 07:47
GAMBIT merge and export mesh sean FLUENT 4 March 8, 2001 07:50
