Riemann problem with two strong rarefaction waves
Old   June 18, 2001, 08:16
Default Riemann problem with two strong rarefaction waves
Alexey
Dear Star-CD users!
I am very interesting how can Star-CD code can solve 1D Riemann problem with two strong rarefactin waves: Heat ratio = 1.4; Left conditions: Density=1.4, Pressure=1, Velocity=-2.5; Right conditions: Density=1.4, Pressure=1, Velocity=2.5; I would be appreciate if anybody send me e-mail with profiles of density and pressure. Please, use the following conditions: Courant number 0.9, uniform grid 1000 cells, number of time iterations - approx. 500-1000.
Thank you. Alexey
Old   June 19, 2001, 16:55
Default Re: Riemann problem with two strong rarefaction wa
John C. Chien
(1). I don't think that the pressure-based formulation is suitable for the transient, shock wave type flow problem. (2). To save the time, why not contact the vendor directly to see whether the code can handle it or not. (3). Based on the published technical papers, this type of problem has been modelled by the density based transient formulation. (4). It is useless to push the code beyond its normal limit of application. (5).On the other hand, I am also interested in the result of this test case.
Riemann problem prapanj Main CFD Forum 3 February 1, 2013 22:04
problem with strong pressure reguer guillaume FLUENT 32 March 13, 2006 04:04
2D Riemann problem ganesh Main CFD Forum 0 October 26, 2005 06:45
Riemann Problem Valdemir Main CFD Forum 1 February 21, 2003 12:06
Riemann problem with two strong rarefactin waves Alexey FLUENT 1 June 20, 2001 13:09
