Starwatch problem and turbulence length unit
Old   August 18, 2001, 10:57
Default Starwatch problem and turbulence length unit
Jiaying Xu
Two other problems in this post:
The first is starwatch problem. During using STAR-CD package, I found sometimes starwatch works fine but sometimes dosen't work. When it doesn't work, the error message in x-term typically is as following:
...iteration result... This Strip Chart will use port 6201. ...iteration result... Warning - Server response timed out. Star job unable to check for registration with starwatch. ...iteration result...
what does this mean? How can I get it work?
Secondly, when I specify an inlet boundary condition, what is the unit of the turbulence length? Is it the standard unit (meter)? If I put 1 as scale factor (STAR GUIde > Analysis Preparation/Running > Run Analysis Interatively > Scale Factor), no problem. But if I put other value, say 0.01, I need to know which value if I should choose for turbulence length of 0.01m, 0.01 or 1?
Many thanks.
Jiaying
Calculation of Drag Force per unit Length Mohammad Faridul Alam CFX 4 January 11, 2013 07:19
WHAT TURBULENCE LENGTH TO USE? RIF Main CFD Forum 2 February 6, 2008 23:17
turbulence length scales T FLUENT 1 August 13, 2007 15:48
Big problem StarWatch STAR-CD 3.26 (Windows XP) Alexey Siemens 2 August 7, 2007 07:45
Turbulence Intensity and Length airfoil Siemens 4 April 12, 2007 01:47
