User specified k-e model
Old   August 30, 2001, 13:20
Default User specified k-e model
Jasper
Hi everyone,
I use StarCD to model laminarising flow in a heat exchanger, and I would like to implement a low Reynolds-number k-e model through the sorkep.f and vistur.f routines.
However, when specifying the use of the subroutine for turbulent viscosity vistur.f, the equations for k and epsilon are somehow inactivated. Unfortunately it is not possible to reactivate epsilon.
Does user-specification of the entire turbulence model require special settings I may not be aware of?
I would greatly appreciate your advice,
Jasper
Ps: It would of course be possible to implement k and epsilon using scalars (and have better control on k-e boundary definition), but that would exclude the use of cyclic boundaries.
Old   August 31, 2001, 11:38
Default Re: User specified k-e model
luis
look here: http://www.stanford.edu/~gmedic/cooling.html
Old   September 5, 2001, 05:08
Jasper
Thanks, I have spoken to Jeong Min Seo. I hadn't realized switch 12 alone invoked vistur.f (Usefull, if you do not want Star to default to VIST = 0.01*VISM in laminarising flow),
Cheers,
Jasper
User Defined Real Gas Model john FLUENT 1 October 25, 2012 14:05
Wall Treatment of User defined Turbulence Model Yang Chung FLUENT 0 August 23, 2008 11:31
Casson Viscosity model as one user define function Zahra Rahmdel FLUENT 0 November 6, 2004 05:53
User viscosity routine and user scalars? Jeff Siemens 3 January 6, 2003 05:26
Problem With User-Defined Fan Model Panel neihad FLUENT 0 November 25, 2001 17:21
