Mesh re-make
Old   January 3, 2002, 09:58
Default Mesh re-make
Julie Polyakh
Is there a possibility to apply an existing model set up (boudaries, scalars, chem. reactions, etc.) on a new (more dense) mesh?
Old   January 4, 2002, 05:45
Default Re: Mesh re-make
john
Yes: just use CREF command to refine the mesh and boundaries will be automatically refined and other setup will be kept.
Old   January 4, 2002, 07:53
Julie Polyakh
Yes, but then I have problems merging vertices. The problem is that I work with 6-degrees sector and merging just deletes the central cells.
Old   January 4, 2002, 09:04
Paal
I think you probably need to adjust the tolerance of the merging so that it is less than the minimum vertex distance.
Old   January 4, 2002, 09:31
Julie Polyakh
The problem is not to adjust it too much. What is the limit value?
How to make the hexaedrical mesh with interface? Rogerio Fernandes Brito CFX 0 December 18, 2008 08:35
how can i make the lanmayi FLUENT 0 November 12, 2008 01:26
How to make UDS ? kimhs FLUENT 0 July 15, 2008 03:07
How to make boundary layer mesh moving with wall wayne FLUENT 3 June 11, 2008 23:23
CFX 5.5 how to make it rotate? Marco CFX 0 November 11, 2004 09:26
