Radial fan
Old   January 12, 2002, 11:18
Default Radial fan
LORENZO ARCANGELI
I'm studying a radial fan using Star-cd, but i don't know how to perform a transient analysis with a sliding mesh. Is there some procedure to follow? Sliding interface...mixasi.... Thank you. LORENZO
Old   January 12, 2002, 17:45
Default Re: Radial fan
James
Yes, have a look at the tutorial. The example with the mixer is similar to your application.
Old   January 13, 2002, 07:14
LORENZO ARCANGELI
Yes, i read the tutorial. I performed a stationary calculation using MRF,on a simplified geometry, but i think it's the right way also for the whole geometry...isn't it? For the transient case i tried with mixasi facilities (see tutorial), but i had some problems, and i don't know if mixasi is right only for mixing vessel or also for a radial fan for cooling or motor engine. Thanks.
LORENZO
Old   January 22, 2002, 03:44
lixhon
you must define group No.,before this ,run vmerge command,then do it according to the turtorial,you will succeed.
Old   February 10, 2002, 15:41
LORENZO ARCANGELI
If I perform a transient run with mixasi command witha tethra mesh the sliding interface must be identical?
Radial gravity Ergys Rexhepi FLUENT 0 December 30, 2008 07:17
radial fan model fidan FLUENT 3 March 6, 2008 20:42
Radial averages smillerhh FLUENT 1 November 8, 2006 07:54
Circum-avg-radial mukkarum FLUENT 0 April 30, 2004 02:34
radial coordinate in UDF varghese FLUENT 1 September 25, 2003 09:43
