strange colors of screen capture
Old   February 25, 2002, 08:10
Default strange colors of screen capture
Jiaying Xu
Hello, there,
I am using StarCD, on a remote SGI machine, to produce some pictures of the claculated result. However, I encounter a starnge problem: the pictures always get an urgly yellow background.
It looks just fine on screen but twists the colors of both foreground and background when saved to a file.
This happens when I use ssh on my linux box to connect the SGI, and disappears when use XWin32 (or Exceed) on Windows 98. But I do need to use Linux much more often.
What I have done to try to solve out the problem: 1) issue xstdcmap -all on SGI then initiate PROSTAR; 2) replace /usr/X11R6/lib/X11/rgb.txt on my linux with /usr/lib/X11/rgb.txt on SGI, restart local X server, ssh connect to SGI, then start PROSTAR; 3) the same as 2), but before starting PROSTAR, issue xstdcmap -all.
All these could not get rid of the problem.
Any suggestion to sort out this annoying problem?
Many thanks,
Jiaying Xu
Old   February 26, 2002, 06:38
Default Re: strange colors of screen capture
Joern Beilke
plot to the case.plot file and convert the pictures after that. In prostar:
term ,, file rast $ repl
produdes a file cassed "case.plot"
Then run the "plot" command from the command prompt to convert the file to something else.
CFX GUI Background Colors UnderwaterAlex CFX 2 February 12, 2008 12:09
Colors and ssh on a Mac julien76 FLUENT 0 December 11, 2006 00:27
How to change line colors in solver? Tony CFX 3 December 15, 2004 11:35
Colors problem in v3.200 Julie Siemens 1 September 23, 2004 03:40
Colors & DXF format in Phoenics. HELP Yiannis Phoenics 3 November 12, 2001 13:00
