Home > Forums > CD-adapco
implicit mrf convergence
Old   April 15, 2002, 05:30
Default implicit mrf convergence
Lorenzo
I'm studying a radial fan (7500 rpm) using mrf-implicit method, but I have a lot of convergence problem.I'm using wall function K-E high Reynolds turbulence model....can someone help me?????
Old   April 15, 2002, 10:44
Default Re: implicit mrf convergence
bosko
use MIXASI and run it moving mesh transient, it isn't as expensive as you think, it is almost guarenteed to work and it'll give you a better answer.
B.
Old   April 15, 2002, 10:53
Lorenzo
How much...expansive????? Plase, if you can give me more details!!!!
Thank you, Lorenzo
Old   April 17, 2002, 15:03
Achim
start with a low rpm, then make repeated restarts while increasing rpm. values for rpm could be 50, 250, 1000, 3500, 7500. some iterations, say 20, per rpm will do. save you postfiles in between ! as soon as you get into trouble reduce the rpm increment. most often the rotational speed of wall boundaries can be fixed at the final value during this process.
something else you can try is to alter the pressure dependence on density during the first iterations.
hope this helps
Thread Tools
Trackbacks are On
Implicit VOF + MRF Grzegorz FLUENT 3 February 27, 2009 08:11
Implicit SPH Tiago Etiene Queiroz Main CFD Forum 2 March 5, 2008 08:25
implicit vs explicit pXYZ Main CFD Forum 2 April 21, 2006 09:48
Convergence with coupled implicit solver Henrik Ström FLUENT 1 October 29, 2005 03:57
how implicit is implicit? Joe cool Main CFD Forum 7 July 16, 2004 11:10
