Any one use Hexpress?
Old   December 16, 2002, 10:37
Default Any one use Hexpress?
Herman
Hi STAR friends. We are considering buying numeca Hexpress for grid generation for car/truck external flow. It is fast and the grids are pretty good but, not many people use it. Could some one tell me if they had bad experience with it?
Old   December 16, 2002, 17:24
Default Re: Any one use Hexpress?
paul
We had a demo for awhile. It makes pretty mesh when it works. The code has both local refinement and "extrusion layers". However, the version we had was 32bit code and somewhat inefficient with memory. If that's still the case, you will run out of cells quickly trying to build aero models.
Old   December 17, 2002, 04:44
gilles
we are using Hexpress since 1 year for internal flow applications using alpha workstations. We have generated models up to 3 millions of cells with local refinements and boundary layers extrusions.
Numeca Hexpress and Fluent V6.2 Saif-Deen Akanni FLUENT 0 October 18, 2006 12:36
Hexpress tech tomosada Fidelity CFD 0 December 13, 2004 08:41
