Cracks - read *.vrt and *.cel
Old   June 11, 2003, 04:31
Default Cracks - read *.vrt and *.cel
Nyquist
I read a model(mesh) creaded by pro*am. I am sure that the model has no error when creating at pro*am. But threr some cracks after I reading the *.vrt and *.cel files? How can I fix the problem? Thank you very much.
Old   June 11, 2003, 10:20
Default Re: Cracks - read *.vrt and *.cel
Joern Beilke
You probably forgot to read the couples (*.cpl).
Old   June 12, 2003, 03:01
Nyquist
But I cannot find where to get *.cpl file. ???
Old   June 13, 2003, 00:02
CJ Tune
It's not saved by default with CDSA. You need to use the Couple Tool to do a 'Couple Write...'.
Old   June 13, 2003, 10:23
steve
CDSAVE saves couples but as CP commands instead of in a .cpl file. No doubt the .cpl file came after the CDSAVE command so it was never changed - but couples are definitely there.
Cracks in Mesh SN Siemens 2 July 26, 2006 05:30
cracks in ES-ICE mesh escapist Siemens 2 July 10, 2005 05:53
Cracks dave Siemens 2 November 23, 2004 04:20
Cracks in the model selen Siemens 1 August 8, 2003 22:22
Cracks Franch Siemens 1 February 14, 2002 08:53
