Velocity overprediction
Old   June 22, 2003, 06:06
Default Velocity overprediction
Julie Polyakh
Hi!
What may cause the flow velocity overprediction of 30% in its maximum point? Problems begin already at the secondary inlet boundary : the U-velocity value after computation is 55% higher than the initial one defined in the BC. The flow swich for BC is 'Fixed Mass'.
Thanks, Julie
Old   June 22, 2003, 23:57
Default Re: Velocity overprediction
cjtune
You should use the 'Fixed Velocity' switch for your second inlet as opposed to 'Fixed Mass'. STAR-CD adjusts the inlet velocity to match the mass flow that you want fixed by (roe)*A*|U|.
Old   June 24, 2003, 04:54
Julie Polyakh
The problem is that I need mass flow to be fixed... There was no overprediction with more coarse grid even with 'Fixed Mass' option.
Regards,
Julie
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
Velocity profile as an velocity intlet condition kees FLUENT 3 April 16, 2008 18:35
velocity profile as an velocity inlet condition KEES Main CFD Forum 0 April 15, 2008 11:26
Temperature overprediction! HP FLUENT 0 June 7, 2005 02:56
drag overprediction Yuri Siemens 10 August 29, 2001 05:53
