one problem about stagnation boundary
Old   July 3, 2003, 05:00
Default one problem about stagnation boundary
Lee
I created a round pipe model,the inflow boundary I set the stagnation boundary,and the other outflow boundary I gave a pressure boundary,because the mode is a axisymmetry model,so I just simulate one quarter of it,then I have set another symmetry boundary at the symmetric planes. The stagnation pressure was set to vary with the time,but when I run the model,star-cd often gave a warning message: " *** WARNING #061 *** RATIO OF STAGNATION PRESSURE AND STATIC PRESSURE AT REGION 1 CELL xxx LESS THEN 1. TEMPORARILY SET TO 1."
And I checked the results I found it was wrong,so I think maybe it is caused by the stagnation boundary,but I must set the inflow boundary as a stagnation boundary,so whether are there guides to help me out this problem? What is the reason to cause the problem?
Your help is great appreciated!
Lee
Old   July 4, 2003, 02:23
Default Re: one problem about stagnation boundary
jing
It is because that stagnation pressure is not a variable in equaitons in StarCD. The solver solves pressure directly, and deduce the stagnation pressure based on corrected velocity. If the initial flow field is not in on a right way, the stagnation pressure will be smaller that the static pressure. This is what the error message means.
Please check the paper: http://www.adapco-online.com/feature_arts/ Paper name: compressible Flows. There are some way to solve the problem.
Good luck.
Stagnation pressure more than 1. hungpavn FLUENT 3 August 9, 2007 06:14
How can I get Cp=1 at the stagnation point ? largeeedysimulation FLUENT 1 September 7, 2005 18:03
stagnation pressure boundary condition xqy Phoenics 6 July 1, 2004 03:43
Help! Stagnation Pressure Leila FLUENT 2 June 28, 2004 07:32
how to set the stagnation pressure boundary xqy Phoenics 4 November 28, 2002 20:04
