July 24, 2003, 06:19 |
drop simulation
Hii All!!!
I'm trying to simulate free fall of drop on a single tube, the area of interest is film thickness. for that i created geometry and solved that but not getting film over tube. does anyone suggest how to approach for that. Is any surface tension function need to be define, or a thin flow of stream would work for that. thanks in advance for your invaluable suggestions and contribution of time for this problem. |
July 26, 2003, 11:06 |
Re: drop simulation
Use the VOF model of STAR-CD (Free-surface flow). You have to define surface tension. For a first analysis, a constant value for the surface tension will do. Try to mesh finer at the walls. As far as I remember, there is a real constant for setting the contact angel at walls. Ask support to provide you the info.
July 29, 2003, 03:55 |
Re: drop simulation
I also think you should use VOF on this topic, but take care of the resolusion. You should at least have about 20 computational within the drop but also in over the thickness of the film.
August 4, 2003, 04:42 |
Re: drop simulation
Thank you for responce, I've completed that with very fine mesh and at a low time step. but I didn't specified any surface tension property as I took the default one for the two surface i.e. between air and water drop, it seems that we can't define surface tension simultaneously for drop and tube surface.
Do u have any suggestion on it, I think that will be help me further to get more realistic results. Please do reply, |
August 4, 2003, 07:41 |
Re: drop simulation
Do the following:
1) SWITCH 23 ON 2) Write the problem file 3) create the ufile directory by typing ufiles at the command line 4) Goto to Utility -> User Subroutines and write out the CAVPRO.F subroutine 5) Edit the CAVPRO.F subroutine and uncomment the lines with SIGMA and CONTANG. This will pass the surface tension coefficient (SIGMA) and the wall contact angle (CONTANG) to the solver. Note that the values are default ones for water. 6) Link your new star executable. Do not forget to include user subroutines. 7) Run & enjoy |
August 5, 2003, 02:39 |
Re: drop simulation
Thank you very much, I will edit that Subroutine. Hope It will work. ;-)
Simulation of pressure drop | Christophe | Siemens | 2 | May 26, 2008 06:02 |
drop simulation | saravanan | FLUENT | 0 | December 29, 2007 14:46 |
drop impact simulation | bhaskar | Main CFD Forum | 0 | February 24, 2007 05:49 |
udf for tank drop simulation? | grexpert | FLUENT | 0 | July 15, 2005 07:58 |
drop simulation | Roxy | Siemens | 0 | July 24, 2003 06:18 |
