July 28, 2003, 22:11 |
CL Front and CL Rear
hello, everyone... Anybody know how to define the CLF(lift front) and CLR (rear) by using StarCd... Normally, starcd gave the overall body fo the lift coeeficient.
I really appreciate if anybody can reply me problem.. thank u.. best regard therry henry... |
July 30, 2003, 10:50 |
Re: CL Front and CL Rear
I think the command ACOEF works only with a current selected set of wall shells... so if you only selected the 'front' of your model then you'll get the force coefficient for just that part. Repeat for the wall shells of the 'rear'.
July 31, 2003, 23:36 |
hay cjtune... thank you for your feedback..is there any simple way to devide the car body.., by using COG location maybe.. .. Where is the limit for the CLfront and CLrear? thank you.. buddy
regards |
August 1, 2003, 03:30 |
Divide at center of gravity? To determine which halve is 'front' and which 'rear'? No idea for cars. With aerofoils it's easy since your have the chord line.
Perhaps where you want to get the CL depends on your area of interest. Say if you want to optimise the slope of the rear windscreen to reduce drag, you might do just as good to just plot out the CL only for that portion. |
Cp values for F3 rear wing for a 4th year thesis | Joe Bryant | FLUENT | 4 | June 10, 2010 23:40 |
Rain on car rear windscreens | Nic | Main CFD Forum | 2 | February 19, 2004 06:49 |
Front Tracking and VOF | Seeker01 | FLUENT | 2 | February 6, 2003 22:52 |
Help needed - lift coefficient on front/rear axle | Jan Jagrik | FLUENT | 0 | September 21, 2000 10:21 |
Rear facing NACA ducts | abn | Main CFD Forum | 0 | January 15, 2000 22:19 |
