Problem in Track Data
Old   August 6, 2003, 13:29
Default Problem in Track Data
selen
Hello everybody,
I have problem in viewing the Track Data File. I created my model and entered the data. There was no problem in the calculation and I can draw the plots but when I try to see the data in Track Data File, it gives the message "No Tracks found in Track data File". What can be the possible problem and solution ?
Thanks a lot, selen
Old   August 6, 2003, 13:33
Default Re: Problem in Track Data
allan
the track data file, I believe, holds droplet data, is this a multiphase problem?
allan
Old   August 7, 2003, 13:06
selen
Yes it is a multiphase problem, which I use Lagrangian.
selen
Particle track data Erik Siemens 2 October 13, 2008 02:56
may i import flow field data to do particle track? Hao FLUENT 8 April 29, 2008 08:22
particle/droplet track data Jay Siemens 1 April 17, 2008 01:28
Particle track James Bewley CFX 0 April 28, 2006 06:04
dpm sample track Gael Corre FLUENT 4 May 9, 2003 13:57
