Particles problem
Old   August 25, 2003, 05:23
Default Particles problem
carno
Hi All, I am simulating a centrifugal pump in which I want to track how fluid particles are flowing. For that I have introduced droplets of same properties as fluid in the fluid domain. The problem is transient and involves sliding rotor mesh. Now problem is that when I post process the results I see the droplets are not moving outside the sliding interface, instead they are bouncing back from that interface which is totally abnormal. In actual case there is no such interface so particles will move spirally outwards. Any idea how can I fix this issue?
Thanks
CFX Particles Jonathan Nebauer CFX 4 January 23, 2009 04:24
Problem trapping Particles with UDF J. Krick FLUENT 2 November 19, 2008 02:28
Problem with adhering particles Ivan Siemens 0 June 17, 2004 06:29
about erosion problem caused by solid particles hannah CFX 4 August 20, 2003 04:42
effect of ventilation on particles problem Jules FLUENT 0 June 10, 2002 14:41
