Erosion problem
Old   September 21, 2003, 03:07
Default Erosion problem
Ko
Dear All,
Is there anyone who has the experience in simulating erosion problem by using STAR_CD? I have done all the jobs, including calculating the two-phase flow and use the subroutines for erosion model as well as rebound model to calculated the erosion. But when I finished all of the procedures, all the data of erosion rate, erosion ratio, impact velocity and impact angle are zeros. Can anyone tell me what happened?
Ko
Old   September 24, 2003, 05:47
Default Re: Erosion problem
Anton Lyaskin
In the 15th issue of Star-CD newsletter there was a small article on errosion modelling. It was done by Wood Group Pressure Control Ltd, you can try to contact them.
Old   September 24, 2003, 07:48
HVN
Sometimes, this indicates that you have some problems with the particule trajectory calculation. Do you check that all particules exit the fluid domain.
EROSION UDF shehab abdelrahman FLUENT 1 February 12, 2008 05:15
Pipe bend erosion problem John Yang FLUENT 2 December 12, 2007 04:06
about erosion problem caused by solid particles hannah CFX 4 August 20, 2003 04:42
Erosion David Connolly Phoenics 1 June 24, 2002 06:16
