raditor flow
Old   October 27, 2003, 00:19
Default raditor flow
carno
Hi, Just an enquiry about how to determine the flow rate in each tube of a radiator. We have one inlet and one outlet. In these in and out there is very good mass balance, but I want to check flow accuring in each individual pipe of radiator. How to calculate that in STAR CD. Help requested.
Thanks a lot
Old   October 27, 2003, 04:28
Default Re: raditor flow
Anton Lyaskin
You can select the cells belonging to one tube, load velocity components, define the cross-section of the tube by comands SPOINT <coordinates of the point in the section plane> and SNORM <coordinates of the normal to the section plane> and use INTEG CSET command.
Old   October 27, 2003, 06:24
carno
Thank you very much Anton
results for flow past flat plate normal to flow lisa Main CFD Forum 2 August 30, 2005 16:36
External Flow-compressible flow solver-lift/drag Tom Brown Main CFD Forum 7 December 29, 2000 13:41
