Extracting information on a particle track
Old   November 17, 2003, 02:18
Default Extracting information on a particle track
Bo Jensen
Hi!
I would like to get the temperature in each cell that a particle track passes through. Is that possible?
Regards
Bo
Old   November 19, 2003, 07:20
Default Re: Extracting information on a particle track
Michiel
Hi Bo,
Yes it is. The variable idc(idr) gives you the cell number a particle is in. You can print these data from the cell number. If idc.eq.0 the particle is stuck in the domain, If idc.lt.0 it has left the domain.
Michiel
This was sent to mee as an example in POSDAT.f by starcd
COMMON /C33001/ IDC
C --- DROPLET DATA
OPEN (UNIT=100,FILE='domain.out')
OPEN (UNIT=101,FILE='evap.out')
OPEN (UNIT=102,FILE='stuck.out')
REWIND (100)
REWIND (101)
REWIND (102)
MASSWO = 0.0
HEATWO = 0.0
DO IDR=1,NDR C --- DROPLET (IDR) IS LOCATED IN CELL (IC)
IC=IDC(IDR)
MASFRA = DRMAIC(IDR,1)/DRM(IDR)
IF (IC.GT.0) THEN
WRITE (100,911) IDR,IDT(IDR),DRD(IDR),DRM(IDR),DRT(IDR),MASFRA
ELSE IF (IC.EQ.0) THEN
WRITE (101,911) IDR,IDT(IDR),DRD(IDR),DRM(IDR),DRT(IDR),MASFRA
ELSE
WRITE (102,911) IDR,IDT(IDR),DRD(IDR),DRM(IDR),DRT(IDR),MASFRA
ENDIF
MASSWO = DRMAIC(IDR,1) + MASSWO
HEATWO = DRT(IDR)*
&(4181.72*DRMAIC(IDR,1)+1750*(DRM(IDR)-DRMAIC(IDR,1)))+HEATWO
ENDDO
CLOSE (100)
CLOSE (101)
CLOSE (102)
Particle Track Domenico FLUENT 2 February 19, 2007 18:56
Particle track James Bewley CFX 0 April 28, 2006 06:04
Particle track files Sankalp CFX 1 August 25, 2004 23:25
Particle Track Zahir FLUENT 16 March 31, 2002 00:29
Particle track code Newbie Main CFD Forum 5 January 22, 2002 08:00
