A problem in valve analysis
Old   February 22, 2004, 21:33
Default A problem in valve analysis
zhpan
There is a case for valve analysis .the detail conditions are as follows: (1)spool is tetra mesh and valve sleeve is hexa mesh. (2)spool move 3 mm relatively to sleeve at a speed of 1 mm/s (3)using moving mesh in analysis
I have some puzzles about this case: (1) shall I use ASI method ? (2) can spool be moved by "case.cgrd" through the event step ? (3) shall I couple the spool and sleeve in the events
appendix: spool(»¬·§·§Ð¾) sleeve(·§Ì×)
Old   February 22, 2004, 21:41
Default Re: A problem in valve analysis
zhpan
I especially want to know (3) : shall I couple the spool and sleeve in the events when using ASI method
gap between valve stem valve kantharao Siemens 0 September 2, 2008 07:19
Globe Valve Aeroacoustic Analysis Mohammad Kordi FLUENT 0 June 2, 2008 04:18
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 12:30
Valve seal problem! Urgent songxguan Main CFD Forum 0 May 11, 2006 22:04
Flow measurement around intake valve pressure condition problem fedegavo OpenFOAM Running, Solving & CFD 1 January 20, 2006 13:06
