Droplet initial location
Old   March 16, 2004, 02:31
Default Droplet initial location
Sang-Jin Lee
Hi, there, There is an example about droplet simulation in STAR-CD tutorial Ch.2. When we use STAR subroutine, DROICO, to place the initial location of droplet, (xd,yd,zd) will be used for it. By the way, in case of that there are two or more initial locations of droplet, how can we make it? Would you please give me an advice? Thanks in advance!
Old   March 17, 2004, 03:28
Default Re: Droplet initial location
Richard
Each time DROICO is called, it can only inject one droplet, whose position, type, velocity etc are specified by XY, YD, ZD, IDRT, UD, VD, WD etc. STAR will keep calling DROICO for this iteration or time-step until DROICO chooses not to inject another droplet. Specifically, until IDRT is returned unchanged from its input value.
Old   March 18, 2004, 22:10
Sang-Jin Lee
Thank you very much, Richard. As result, you mean it's impossible to make 2 or more droplet initial position by using STAR-CD? I heard it can be with local coordinate system, but I'm not familiar with it. Perhaps do U have an idea about it?
Old   March 19, 2004, 03:46
Richard
You can definitely inject more than 1 droplet with DROICO. My last posting was my best attempt to explain how to do it. Maybe if you look at the example coding which is commented out in the header of the subroutine? I seem to remember this shows how to inject 10 droplets.
Old   March 19, 2004, 10:46
Michiel
Hi there,
I think this will solve your problem.
EQUIVALENCE( UDAT05(001), IDR )
now you can program a initial location depending on the idr number. for example
n=mod(idr,max_init_locations) if (n.eq.0) n=max_init_locations if (n.le.10) then xd= yd= zd= elseif(n.le.20) then xd= yd= zd= elseif xd= yd= zd= endif
good luck
Old   March 19, 2004, 19:18
Sang-Jin Lee
Thank you very much, Richard and MIchiel. I had misunderstood what you explained to me at first, Richard. I'm sorry about it and thank you again. Now I can make more than 2 holes. Michiel, your kind explain was so great. Thank your really so much.
Particle location ehsan FLOW-3D 3 June 17, 2014 07:14
Variable initial droplet diameter Sam FLUENT 0 June 4, 2005 11:36
monitor the location of MAX value bogesz CFX 3 February 14, 2004 00:11
Initial droplet size distribution Ossi Kaario Siemens 2 March 13, 2001 12:19
Location of vortices Tony Dodd Main CFD Forum 4 July 28, 2000 22:14
