how to transport parameter between subroutines
Old   March 17, 2004, 03:02
Default how to transport parameter between subroutines
Jane
hi, experts
i meet a problem, for example: after calculating some parameter which is defined by myself through posda.f, i want transfer these data to another subroutine sorent.f to change the heat source term for every cell.So i add a commom sentence in these two subroutine to try to transfer the calculated data. but it seem it wasn't transported from posdat.f to sorent.f.(i add some 'write' in the sorent.f). if some one have these experience or have some idea about how to transfer the data between subroutine, please tell me , thank you very much.
jane
Old   March 18, 2004, 08:14
Default Re: how to transport parameter between subroutines
roadracer
I noticed the same behaviour using sorsca,scalfn posdat and initfi. It didnīt work until I put the common block definition in initfi.f
Old   March 18, 2004, 08:56
Jane
Hi, Roadracer
I spend whole day, and finally I got it, I make it runing successfully. It is ture I also use the common block to solve it. anyway, thank you for your mention.
Jane
subroutines in UDF kk FLUENT 3 February 9, 2007 01:38
CFX subroutines Neser CFX 0 November 8, 2005 23:07
subroutines Jared Siemens 1 August 25, 2005 13:38
fft subroutines pratap Main CFD Forum 1 August 6, 2003 16:49
HPC and subroutines Steve Siemens 20 March 7, 2003 09:12
