CHT problem
Old   May 21, 2004, 03:07
Default CHT problem
novice
Hi Experts, I have simulated a Conjugate HT problem. That worked fine but results were little away from analytical calculations. The need was to refine the fluid mesh. So I refined the fluid mesh and coupled unchanged solids to it. Then I am facing the problem of convergence in solids. I tried reducing the under relaxation factor for fluid and solids independantly, but in vain. How can I solve this problem? help requested.
Old   May 26, 2004, 08:03
Default Re: CHT problem
Leo
You cannot have couples between fluid and solid interfaces. They must match vertex to vertex. You should also starlink with double precision.
VOF diffuse problem on two fluids problem Fang Jin FLUENT 5 February 17, 2011 05:38
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
Problem in cavity flow problem saad Main CFD Forum 4 November 1, 2007 07:45
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
