couple and spin index
Old   July 7, 2004, 06:52
Default couple and spin index
novice
Hi Experts, Can I have couple in between two cells which have different spin indices. They are in partial overlapping.
In userguide it is written that couple is not possible when cells have different spin or/and porocity indices, and also between fluid and solid cells. Since couple between fluid and solid cells is possible I took doubt on former also. So please guide how to give couple between cells with different spin indices.
Thanks a lot.
Old   July 7, 2004, 06:58
Default Re: couple and spin index
4xF
As stated in the manual, you cannot have couples between two cells having different spin indices.
Old   July 7, 2004, 07:37
Thomas
and you have couples between solid and fluids but no partial couples, this will not work!
Old   July 7, 2004, 07:48
Richard
The only way to join two cells with different spin indices is MRF. If the cell faces match 1:1 (no couple required) then you can choice implicit MRF or boundary-coupled explicit MRF. If the cells don't match 1:1, you need region-coupled explicit MRF. This isn't a subject you should wander into by accident, it's quite complicated, so be sure you need this functionality before you start work on it.
Old   July 7, 2004, 08:07
novice
Thanks for replies.
But in case of explicit MRF it asks for material no. I have only one material (fluid), but part of it is rotating and part is not rotating. As far as I know we can not have two material numbers with same properties. In case of 1:1 matching there is absolutely no problem, since we can give different spin indeces and use implicit MRF. I am still unanswered how to sort out my problem: Coupling between nonmatching fluid meshes which have different speeds. (one is stationary and other is rotating).
Thanks in advance.
Old   July 7, 2004, 08:50
4xF
As Richard stated, you have to use regionwise coupled MRF (see manual for details, since only certain type of region combinations are allowed, e.g. inlet/pressure).
Old   July 8, 2004, 03:31
Richard
There's no reason why you can't have two materials with the same properties: that is exactly what is required for explicit MRF. In implicit MRF, the rotation is specified by spin index, in explicit MRF it is specified by material index.
How to spin the ball in Fluent? dude Main CFD Forum 1 December 24, 2008 21:53
how the disc spin h.k.moukhtar Phoenics 1 March 15, 2006 04:41
Spin coating Jay FLUENT 0 September 6, 2004 22:19
spin coating JH FLUENT 0 July 23, 2004 20:32
low-re-ke-index WHO KNOWS? michael_nurzynski FLUENT 2 July 19, 2004 05:11
