How to read a file from a macro
Old   July 7, 2004, 15:17
Default How to read a file from a macro
StarCD
Hi everyone,
I have a text file with x and y vertex co-ordinates of a geometry. I would like to write a macro to read from this file. How do I do this? Someone mentinoed something about IFILE command. I need more detail as I dont know much about writing the macro apart from the simplest terms.
Please help.
Thanx, StarCD
Old   July 8, 2004, 21:29
Default Re: How to read a file from a macro
steve
A macro can have any set of std prostar commands. The prostar command for entering vertices is
V,vertex#,x,y,z
If you modify your file to the lines above, rename it casename.inp and then use ifile,, you can read in those numbers. However, if all you want to do is just read in coordinates, you would be better off looking at the help for the VREAD command and put your file in the format that VREAD looks for.
Old   July 8, 2004, 21:31
StarCD
Thank you Steve
read file in UDF Echo FLUENT 4 July 4, 2017 12:37
using UDF to read file Ellen FLUENT 5 November 25, 2008 17:38
Macro file. Jwala CFX 0 November 14, 2008 04:18
read data file sandra FLUENT 5 August 24, 2006 05:42
Read file RBM FLUENT 0 July 14, 2002 13:48
