is proam one huge bug???
Old   July 26, 2004, 08:35
Default is proam one huge bug???
F.K.
Hi all,
who actually can import cel and vrt files with the latest linux proam version? I can't believe proam always doubles the surfacemesh. Try the following:
open meshwizard read STAR-CD Cell/Vertex File TOOLS- CELL TOOLS - CELL LIST
mesh is doubled and you can't work with it anymore!
real nice
Old   July 26, 2004, 09:56
Default Re: is proam one huge bug???
Jörn Beilke
just use cread and vread from the command line
Old   July 27, 2004, 15:15
kevin
hmm, it doesn't appear to double up on me
here is what I just tried:
1) start proam 2) vc3d 0 10 10 0 10 10 0 10 10 3) cset all 4) live surf crea 5) cset news fluid 6) cdel cset 7) cset all 8) cplot 9) cdsave
now I have 600 surface shells in my .vrt and .cel files. If I restart proam and import using the mesh wizard, I still only have 600 surface shells.
Or am I misunderstanding your problem?
Old   July 28, 2004, 03:06
F.K.
I have a mesh generated with ICEM. cel vrt inp files are exported from ICEM which should be imported with the mesh wizard. Promam reads all the vertices and cells without any complaints but when I open the cell tables the surface mesh is doubled. You are absolutly right. If you generated the mesh with the command line or if the mesh is read in with cread the problem dos not arise. This means Don't use the wizard under Linux and everything is fine!!
have a nice day
huge difference in running time Jimmy Main CFD Forum 5 July 18, 2008 22:29
Huge meshes on clusters Mads FLUENT 3 March 23, 2008 06:36
Solver is finishing with huge Mach number Fonzie CFX 1 March 12, 2007 14:15
why the pstt file is so huge? Lee Siemens 2 September 17, 2003 17:26
How to extract streamlines from huge files? Markus Weber Main CFD Forum 3 August 3, 2000 09:28
