HELP! HELP! HELP! ext. Flow aerodynamics
Old   August 4, 2004, 21:50
Default HELP! HELP! HELP! ext. Flow aerodynamics
moya bucho
hey... I tried to simulate external flow of aerodynamics but with rotating wheel and relative movement of the ground to simulate an actual scenerio car travel at highway. My question is, how to model rotating wheel? how to model moving ground.?
or can we just using boundary condition for this to condition?
Please educate me.....
Thank u in advance..
moya..
Old   August 5, 2004, 05:39
Default Re: HELP! HELP! HELP! ext. Flow aerodynamics
Anton Lyaskin
You can simulate both by assigning wall velocities. Make each wheel a separate wall boundary region, define the cylindrical coordinate system in the center of the wheel, in boundary conditions select this system for wheel boundary and specify RPMs. The same way works with ground - specify a proper cartesian coordinate system and set the necessary component of the velocity.
Old   August 6, 2004, 03:30
moya bucho
Thank you very much, for your help...
Moya...
Car aerodynamics morfeus80 OpenFOAM Running, Solving & CFD 109 November 13, 2012 17:12
Aerodynamics vengi FLUENT 5 October 25, 2011 10:43
CFD in aerodynamics Ujjwal Bhaskar FLUENT 1 December 26, 2007 10:29
Use of Pro-Am in aerodynamics Javidan Ahmad Siemens 8 December 2, 2004 23:27
Aerodynamics of Cross flow fan Yerram Ravinder Main CFD Forum 1 September 6, 1999 01:07
