tutorial for windows machines
Old   August 2, 2004, 01:23
Default tutorial for windows machines
Arnab
Does anyone have any tutorial or some excercise on Moving meshes on windows machine so that I can go through them and work on my moving mesh problem which I have to work on windows.
Incase anyone has any tutorial specifically for windows machines, then please do send me.
Thanks in advance,
Old   August 2, 2004, 04:29
Default Re: tutorial for windows machines
4xF
As far as I know, you cannot run moving mesh simulations under Windows.
Old   August 2, 2004, 06:35
HVN
There is no tutorial specific to Windows because it is the same command in Linux and Windows. The difference is for the run of a calculation.
HV
Old   August 2, 2004, 22:08
Arnab
Hello HVN,
What are the differences in the run of a calculation using windows. It would help me if I know better the differences.
Arnab
Old   August 3, 2004, 03:14
vladimir
Hi Arnab
Which version of star do you use? If older than 3.2 then it should work as tutorial no.7 says (you have to run pmovlink manually). In 3.2, there is no special treatment just follow the tutorial.
Hope it'll help.
Old   August 3, 2004, 03:40
HVN
You must use the starlauncher for windows
Old   August 3, 2004, 16:35
Arnab
what is correct?
Can we run moving mesh simulations in windows???
Or do we need to install fortran compiler to run moving mesh in windows?
Is just the Exceed enviroment sufficient for running moving mesh problem?
Old   August 4, 2004, 02:51
HVN
Yes you could perform moving mesh simulations in windows. But you need 2 tokens of licenses: one for prostar and another one for star. prostar will be used to move the mesh and star to calculate the flow.
Old   October 14, 2004, 19:59
rivers
agreed. tmobil has developed the same technology. www.uscomco.org/Cellular/tmobil_T-Mobile.html
queries of star-CD on windows machines Arnab Siemens 3 April 6, 2011 10:13
Specifying multiple machines with a machines file mellanoxuser OpenFOAM Installation 0 February 6, 2008 18:24
earth runtimes on different machines Nick May Phoenics 1 April 27, 2004 00:36
Clustering of Linux machines Ajay s. Parihar Main CFD Forum 6 January 24, 2003 15:47
733 MHZ machines John McGrath FLUENT 1 January 26, 2000 03:50
