Internal Closed Volumes in Pro-AM?
Old   October 6, 2004, 17:57
Default Internal Closed Volumes in Pro-AM?
Ted Crilly
hi star users,
i'm looking to model a domain with a number of internal sub domains or volumes that are hollow and will not contain any internal mesh data, just surface mesh, the mesh wizard reports problems at the end and the mesh is unusable,
the geometry is imported from cad data and pro-surf used to create db file then import into pro-am and the mesh wizard takes over
can anyone help here? i tried the manual but cannot find any help, i'm using Star-CD 3.15A
thank you
ted
Old   October 7, 2004, 04:27
Default Re: Internal Closed Volumes in Pro-AM?
new-user
Hm... I have created such a mesh without any problems, which is the best situation for the 'new-user' ;-) (3.2). Perhaps you should check the surface cell orientation??? Anyway your surface checks have to show no errors, and usually you get the information what the error is about and the remedys are in the manual.
It is possible that proam just doesn't recognise the outside of your model - so I guess some of the surfaces are not closed, or the shells are badly oriented...
oh, and maybe do not use the wizard, but just the normal proam surface tools...
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Meshing & Mesh Conversion 2 March 30, 2009 15:02
how to get fluid internal internal energy vbk FLUENT 0 December 17, 2007 01:54
Combustion in a closed System Martin Castillo FLUENT 3 June 20, 2007 21:38
bc for closed tunnel Hanni FLUENT 0 March 14, 2007 21:06
closed end geometry Rashmi FLUENT 1 January 15, 2007 00:40
