Comet - air velocity
Old   October 26, 2004, 15:13
Default Comet - air velocity
Tony Campbell
Hi folks, Using the post-processing command (plfi vel), in a air water interface problem, i see both the velocity vectors for air and that of water. i guess because the air is lighter, air speed is higher and the vectors have a huge compared to that of water (this is the required vel). i was wondering if there is a way of getting rid of the air velocity at the air-water interface. any help would be greatly appreciated.
probably there should be a way of using the concentration parameter, but i cant figure out how!
thanks for your continued help!
Old   November 3, 2004, 14:00
Default Re: Comet - air velocity - have same problem
emmanuel
i have the same problem..anybody with any ideas??
Old   November 7, 2004, 06:57
4xF
I guess that you have a huge smearing of the volume-fraction over there or that you have not converged correctly within every time step, which would explain why you'd have such big differences in the velocities. Anyway... If you want to get rid off the air velocity for the display and if SP1 is the volume-fraction of water in air (i.e. Sp1=1 => 100% water), here is the Cometpp macro you need (please feel free to improve...) For the command details, RTFM
%% load velocities into register 1 to 3 stlo 1 u & stlo 3 v & stlo 3 w %% load species 1 into stack 4 stlo 4 Sp1 %% multiply velocity with Sp1 => water only stma mult 1 4 1 stma mult 2 4 2 stma mult 3 4 3 %%% display popo all new vect popo all add edge deco coun on 'Vel. [m/s]' plex
Have fun...
Old   November 10, 2004, 02:37
emmanuel
superb! it works. thanks.
Comet FSI Erik Siemens 0 July 19, 2005 16:23
comet? Thomas Siemens 2 November 15, 2004 03:30
Comet Harichander Siemens 3 May 5, 2003 01:14
COMET??? Dougal Main CFD Forum 1 April 6, 2003 19:49
[about COMET] CFDer Siemens 1 March 28, 2003 06:02
