changing boundaries
Old   February 23, 2005, 04:56
Default changing boundaries
sankar
I want to simulate a model with let say five inlets and one outlet,but all inlets should not work at a same time that means inlets are time dependent. Suppose i want to trigger first 2 inlets rest inlets should be treated as wall and then as one time step is over next inlets should be triggered. STAR-Cd user guide says we can do that by advanced transients option and GT-power but how to use that and how to redefine the boundary type e.g changing from wall to inlet and vice versa i dont know. If anybody help me out of this i wld be grateful.
Old   February 23, 2005, 08:53
Default Re: changing boundaries
Pauli
Can you leave it as an inlet and set the velocities to zero? In other words, when an inlet isn't flowing, you live without wall type functionality - say heat transfer or wall functions.
If so, you can define a time dependent velocity with a table or user subroutine (I believe it's bcdefi.f).
Old   February 24, 2005, 04:06
Brian
The correct way to do this is using load steps - see "Analysis Controls for Transient Problems" - "Load-step based solution mode" in the User Guide.
Old   February 25, 2005, 01:38
sankar
in user guide they are not specifying any info about changing boundary type with change of time. any other help is available anywhere?
Old   February 26, 2005, 05:33
Brian
The boundary conditions, together with boundary types, are saved for each load step. So create a load step, set up the boundaries for that load step, then save the load step. Repeat for each load step - you can change boundary type as well as values.
Also note the use of ramp or step changes in load steps.
UDF for changing viscosity Rafael FLUENT 2 October 28, 2009 15:59
Changing RPM Amir Hossein Birjandi FLUENT 2 March 4, 2008 00:51
changing co-ordinates Mac Siemens 1 December 27, 2007 08:38
changing of k-e model Sima Baheri Phoenics 0 May 18, 2006 04:52
Changing BC Riham FLUENT 5 January 15, 2004 20:54
