how to many transient figures by command
Old   January 12, 2005, 23:44
Default how to many transient figures by command
lenson
recently I do some transient cases . after computation , I should get figures with which to compare. But I have 200 pics need done. Can anyone tell me how to get the gif.pictures by using commands. thanks for help~
Old   January 13, 2005, 02:44
Default Re: how to many transient figures by command
yacine
you can find a small example of script to generate pictures in the manual (star guide) using loop comand to download data from *.pstt file and plot them have a look.
Old   January 13, 2005, 05:40
Peter
What would be the commands to export some .gif files? For example: number of gifs "i", name "i.gif" i=1..10(1)? Can you give an example? Thanks!
Old   January 13, 2005, 06:07
Jörn Beilke
scdu gif
*defi noexec
repl
*end
*loop 1 10
scdu off
Old   January 13, 2005, 06:09
Anton Lyaskin
Look for help for scdump command. It can produce gif files for you
Old   January 13, 2005, 06:43
carno
Look what Jörn has said. It is the best way to do. Create variable within the loop and use trload command to load particular load step. In past I have generated more than 500 images in transient cases within munutes by such macro.
Thanks
Old   January 13, 2005, 10:34
ted
There are a couple of other ways to output pictures from pro-STAR, both of which can be used in a *loop, as previously described.
If you run pro-STAR in GLM mode, you can get high quality screen dumps using "HRSD".
Alternatively, you can use the .plot file, which allows you to produce figures in a varienty of formats.
In pro-STAR: term,,file rast *loop 1 10 1 term,, close .plot
Then on the command line, use the "plot" utility to generate the files in the format you want: plot gif
Old   January 19, 2005, 10:43
tak
hai
i am working with ic engines for tranisent ( moving mesh), can any one explain in detail how to write a macro to capture figures ( one complete cycle) for any variable ex..velocity vector plots. thanks in advance
anand
Old   January 21, 2005, 03:41
lenson
the following codes used in my simulation can work you can take it as a reference
scdu gif *defi noexec *set I 1 1 % I is for loop parameter from iteration to 40 by 1
store,iter,I
% just add the command button then you can find % which command code is according.step by step % you can fill folling code
psys,1 getc,all,none spoint,0,0,0,0 snorm,1,0,0,0 plty sect, $edge,on $popt,vect $thin,1 $term,,,vect $repl
*end *loop 1 40 scdu off
How to make Disproportional Figures - Postprocess. mrt FLUENT 2 December 29, 2007 08:13
Gambit, how to generate figures? Jim Clancy FLUENT 2 July 21, 2006 07:44
command for transient computation Patrick FLUENT 2 May 19, 2006 15:09
Help regarding high quality figures from CFX-post UY CFX 4 August 29, 2005 16:37
Help ...MY FLUENT CAN NOT SHOW figures Dandy FLUENT 2 September 8, 2003 23:55
