How to create multiple solid-fluid domain?
Old   January 26, 2005, 01:29
Default How to create multiple solid-fluid domain?
Harendra
Dear Experts,
I want to simulate a shell and tube heat exchanger. How do I create tubes with finite thickness with different fluids outside and inside?
Regards,
-Harendra
Old   January 26, 2005, 03:20
Default Re: How to create multiple solid-fluid domain?
Richard
One of the tutorials is about a fin heat exchanger. Have a look at that one to see how to have a solid material and a fluid material and join them together.
To actually generate the grid for your case, you could use
Create and Import Grids -> Create Grids -> Create 3-D Grids
and define the extent of the tubes and the fluid parts seperately in a cylindrical coordinate system. Choose a different cell type for each part, so that it is easier later to assign them to different materials. You can have different fluid materials in your model as long as they are separated by baffles or (in your case) solids.
Old   January 26, 2005, 06:14
Harendra
Hi Richards, Many thanks. I hope in this way I could be able to do. But if I draw a model using other softwares sucy as SolidWorks or others, then what I have to do to specify separate solid fluid regions? Regards,
-Harendra
Old   January 26, 2005, 13:58
Brian
This sort of model is really not suited to automeshing, like through Solidworks etc. A good opportunity to learn REAL meshing.
Old   January 26, 2005, 16:41
steve
it is possible in stardesign with imprinting
Old   January 27, 2005, 09:41
Default What is imprinting or real meshing??
Harendra
Old   January 28, 2005, 13:58
Default Re: What is imprinting or real meshing??
Brian
I have no idea what imprinting is, but "real meshing" as I meant it, is building the mesh yourself rather than relying on an automatic mesher.
multiple fluid domain Sumedh CFX 10 December 14, 2016 16:36
how to assign multiple fluid domain with different jai CFX 1 March 10, 2009 03:01
How to create and define multiple domain? mishar CFX 4 February 3, 2005 07:31
How to create multiple domain? Mishar Siemens 2 January 28, 2005 09:41
How to create multiple solid fluid domain? Mishar FLUENT 0 January 25, 2005 03:05
