How to delete cracks
Old   February 3, 2005, 12:39
Default How to delete cracks
Raghavendra
Hello every one, can you give me some ideas...how to delete cracks..can we delete directly or we have to use any command...
please help me in this regard
Old   February 3, 2005, 23:09
Default Re: How to delete cracks
steve
A crack is not something you can delete. Its an indication of an error in your mesh that you have to fix. A crack exists because the mesh is not topologically continuous. It may be that you have to merge coincident vertices (VMERGE) or if you have non-matching cells you have to create couples (CPMATCH).
Old   March 17, 2005, 00:33
Suresh
As a Continution of the above, is it possible to give boundary condition where Couple is created? suresh
Old   May 24, 2005, 01:15
Hubert Janocha
It is very important to delete cracks, as they occur as a wall in the fluid domoian. Because no couple is defined for a crack, ofcourse no couple error will be shown. I fix it this way. - let Nav-Center make a cset of the cracks - give the cset a new cell id, to locate the cells every time without makeing a very time extensiv crack-check again. - cset from one failed mesh location. - grow set to have a master and all there slave cells. I make a vset to add cells to that cset. - be sure that in the cset every master cell has all his slave cells, because when you delte a possibly couple a such an uncomplete pair of cells you generate a couple error. - generate a new couple. - give back the repaired cell set the original cell id. - look at another failed mesh location.
Cracks dave Siemens 2 November 23, 2004 04:20
Cracks - read *.vrt and *.cel Nyquist Siemens 4 June 13, 2003 10:23
Cracks Franch Siemens 1 February 14, 2002 08:53
cracks in the model Sabatini Siemens 4 January 30, 2001 07:13
How to fix cracks in a tet mesh Ron Siemens 1 August 14, 2000 20:07
