past itteration register value
Old   March 13, 2005, 13:24
Default past itteration register value
cmv
Hi it is me again!
This is a programming question, do you know how to define a vector that could give you the value of a variable calculated one iteration before. In posdat.f, this could mean a variable 'A' that gives you the value of variable 'B' calculated on the past level. For example you calculate B as a function of the mass fraction of scalar 1: B=t(ic,2)*alpha, and you would like to know what this value was the last time it was calculated: A=B(past), not this level or itteration the "past one".
Many thanks CM
Old   March 13, 2005, 13:52
Default Re: past itteration register value
Richard
In each iteration you calculate B and then set A=B. As long as A is either SAVEd or it is in a COMMON block, it will be "remembered" in the next iteration (up until the point when you do A=B anyway).
post register operation star Siemens 2 July 20, 2007 03:03
Post Register anonymous Siemens 3 July 10, 2006 06:47
How to get data out from register? leo Siemens 1 May 2, 2003 08:16
post register Astrid Hostrup Siemens 1 July 31, 2000 08:11
