Environmental Pressure BC
Old   March 25, 2005, 02:48
Default Environmental Pressure BC
Shazlan
Hi all,
When implementing a pressure BC with the environmental option on, does star-cd automatically assumes that the pressure over that region is atmospheric pressure? if not, for the sake of clarification, do i need to specify the atmospheric pressure (101325 Pa) in the pressure section?
Also, what are the differences if i specify the pressure in the pressure BC tab and if i specify the pressure in the initialization tab? what i want to achieve is to set the pressure over some certain region (volume), which includes the boundary, to be atmospheric. am i on the right track?
please advice. thanks!
Old   March 26, 2005, 08:20
Default Re: Environmental Pressure BC
Anton Lyaskin
1. The pressure specified for "Pressure" regions in Star-CD is ALWAYS relative pressure referenced to Reference Pressure in Initialization and Reference Data. By default it's 1e5 Pa, so if you want atmospheric pressure in your region just set 0!
2. Environment option means that "environmental losses" will be automatically taken into account if you pressure boundary will act as inlet boundary.
All this information can be found in the manual.
How to setup environmental variable thandavan CFX 1 June 16, 2006 06:24
Environmental CFD Henry Main CFD Forum 2 November 21, 2002 04:03
Environmental CFD Hurricane Andrew Main CFD Forum 0 May 11, 1999 12:21
CFD Applications in Environmental Engineering Andy Main CFD Forum 3 March 29, 1999 01:25
Environmental fluid mechanics Donald D. Gray Main CFD Forum 2 September 25, 1998 15:54
