Meshing Units
Old   July 20, 2005, 05:22
Default Meshing Units
Nalleli
Hi
I transfered a .igs file to Pro-am to mesh, the units where mm and when tranfered it changed them to {m), how can a change the units of the whole mesh without redoing the whole mesh again?
And to avoid this happening again how can i tell when a transfer a file to pro-am that it respects the units of the geometry?
Old   July 20, 2005, 05:24
Default Re: Meshing Units
Ben
the units in pro-STAR (and pro-AMM) are all the same 1 to 1 so you mesh is in pro-STAR units, if you want to run it in mm you just need to set the scale factor on the geom write.
Units? Skander FLUENT 1 February 5, 2007 09:10
Units GAMBIT VIRGINIE FLUENT 2 November 10, 2005 17:37
What's the units in UDF? Erica FLUENT 3 March 3, 2005 18:40
What's the units? ocy FLUENT 3 February 23, 2005 21:40
Units of P CFD guy Phoenics 1 December 29, 2004 05:35
