moving grid
Old   August 12, 2005, 06:14
Default moving grid
Dr C.Bhasker
I am interested in usage of an application through star-CD. Can any body suggest where exactly related tutorial is available. If not, I request software support engineers to provide pdf file electronically.
Thanks!
Dr C.Bhasker
Old   August 12, 2005, 08:39
Default Re: moving grid
Ben
related to what?
Old   August 12, 2005, 11:38
Dr C.Bhasker
Automobile piston-cylinder circuit breaker SF6 gas normally comes the standard tutorial with software but not available.
Thanks
Dr C.Bhasker
Old   August 17, 2005, 04:11
rajesh
You can refer tut 13 of STAR-CD (prostar) regarding moving mesh with piston cylinder arrangement.
All the Best Rajesh
Old   August 31, 2005, 02:29
Hubert Janocha
Good luck with tut13. That will take some time for understanding for a beginner.
Another possibility is ProICE bei adapco as a mesh generator for comb. engines. ProICE helps you to define the event modeller in a´much esier way.
If possible use this, but it is much expensive.
moving grid mazaheri FLUENT 1 July 19, 2006 12:07
Grid Moving Karthik Krishna FLUENT 4 February 23, 2005 07:57
HELP: moving grid Sunlight007 Siemens 0 June 5, 2003 17:11
moving grid Vikas Kumar Main CFD Forum 1 May 5, 2003 05:14
Moving grid(BC) faithkim Main CFD Forum 11 September 11, 1999 14:07
