Cylinder + Sphere mesh
Old   September 12, 2005, 02:35
Default Cylinder + Sphere mesh
bk
Hello everyone.
I want that a sphere(diameter=10mm)is inserted into a cylinder (diameter =20mm) at center point of cylinder.
How to mesh these grid?
Do I mesh each one respectively?
How to add some part with the other part?
Thank you.
Old   September 16, 2005, 07:05
Default Re: Cylinder + Sphere mesh
Ahmad Al-Zoubi
If you have stardesign you can make it very easily. Just draw the cylinder and the sphere, then press on the cylinder and using the ctrl botton press on the sphere, then press the SUBSTRACT botton in stardesing.
if you haven't stardesign but you have proam and prostar, make the grid in prostar and then use the "live, surface " command to make a shell for your geometry. delete the fluid cells and continue in proam to generate the grid.
if you have only prostar it is not so easy if possible.
Ahmad Al-Zoubi
[blockMesh] Create a mesh for flow around a sphere harly OpenFOAM Meshing & Mesh Conversion 7 November 6, 2013 16:28
Flow around a sphere and a circular cylinder Francis Main CFD Forum 0 September 29, 2008 05:16
hexa mesh around a sphere within a cylinder HK FLUENT 1 March 21, 2008 08:15
hexa mesh around a sphere within a cylinder:fluent HK Main CFD Forum 1 March 20, 2008 10:54
CFX cylinder or sphere benchmark results Mel CFX 1 August 8, 2005 18:47
