mesh generation
Old   October 4, 2005, 04:38
Default mesh generation
ramesh
dear star users; i am the beginner level starcd 3.22 windows.,
when i create mesh using NAVcenter ,i am unable get the "generate mesh " button,,
but any where in the tutorials they have specified click "generate buttomn"
also tell me how custamize button,fonts etc
ramesh
Old   October 4, 2005, 06:39
Default Re: mesh generation
bv
I think u have opened PRO STAR.
Pleasec open PRO AM for meshing.
BV
Old   October 6, 2005, 04:27
ramesh
thanks a lot..
please tell procedure i have to follw so that i can pick starcd quicker...
Old   October 7, 2005, 03:30
ramesh
dear BV and star cd users ;
still i unable to find "generate mesh" button missing in Pro/amm...
please help me to solve this problem...
i am following first tutotials "laminar flow in labrrynith"
thanks in advance ramesh
Old   October 7, 2005, 03:49
Ted Crilly
dude, you should check the Pro-am manual for instructions on how to generate you mesh, unfortunately its not just a single button to press and the mesh is automatically generated
Pro-am is setup to do the following
Import Surface Surface Cleanup Subsurface Generation Mesh Generation
you import geometry in relevant format and start from there,
I believe the tutorial you are talking about the mesh is manually setup using the pro-star interface,
Simply follow the instructions,
I would sugguest sticking with pro-am and using the pro-am manual and pro-am tutorials to see how its done, the first few tutorials are relatively easy
Old   October 7, 2005, 09:28
saravanan
Hai
For ur query regarding 'Generate Mesh' Button,follow the instructions below.
Nav Center > Select Analysis Features>Create and Import Grids>Create Grids>Create 3d Grids using simple shapes>Generate Mesh.
Good Luck Saravanan
Old   October 10, 2005, 06:34
bv
Hi ramesh,
I will suggest u first to work on some simple problems like cube...etc to get used to commands and panels.
Try soliving pro-AM tutorials..which will help u to generate mesh.
Bv
mesh generation srinivas Siemens 1 September 13, 2007 00:46
mesh generation srikanth Main CFD Forum 1 January 26, 2006 05:02
RE. Mesh Generation Help Patel Amit R. FLUENT 0 July 12, 2003 02:03
mesh generation Matthias Main CFD Forum 0 February 4, 2002 09:22
MESH GENERATION SANJIB DAS SHARMA Main CFD Forum 7 May 13, 2000 07:16
