call posdat.f at the end of the run
Old   October 15, 2005, 22:12
Default call posdat.f at the end of the run
Murali
This is a question that I saw in Jul 2005. To my knowledge this can be done as follows:
(1) POSDAT has the vairable RESOR passed into it by default (2) RESOR (IV,IMAT) is the residual of variable IV in material IMAT. IV is the variable number like U=1, V=2 etc. Refer to nom.inc for the details (3) Write an IF stmt in POSDAT using LEVEL Eq 2. I think the program visits POSDAT once before and after iteration even after convergence. Else use level 1 (4) The IF stmt must have max(RESOR) to be verified with the set tolerance SETTOL. if max(RESOR) <SETTOL it means, the convergence criterion is attained and iteration is about to stop. (5) Write the values using POSDAT.
Hope this helps.
Old   October 16, 2005, 02:48
Default Re: call posdat.f at the end of the run
Boban
Thank you very much for your help. It works in way you described.
Old   October 16, 2005, 12:02
Murali
Glad to be of help. I was investigating this myself to write from POSDAT after convergence for some problem. Thought I could share. Good luck.
CFL in posdat hamodi Siemens 2 August 6, 2007 02:27
POSDAT Sheila Siemens 2 February 8, 2006 11:08
call posdat.f at the end of the run Boban Siemens 2 July 15, 2005 16:24
posdat in HPC Won-Geun Lee Siemens 0 May 23, 2001 20:03
Posdat Maria Carlsson Siemens 1 April 30, 2001 10:29
