How to create file cgrid.cgrd from tutorial 11.1
Old   November 9, 2005, 00:43
Default How to create file cgrid.cgrd from tutorial 11.1
dila
Dear All, I am a novice in star cd, and now I am trying to follow tutorial 11.1 of star-cd ver 3.22. But I face a problem when trying to follow the instruction for creating cgrid.cgrd file. What is actually I have to do? Thanks
Old   November 10, 2005, 04:32
Default Re: How to create file cgrid.cgrd from tutorial 11
Anton S. Lyaskin
In ProSTAR main menu: File -> Edit File... This brings the simple text editor. Just type and save
Old   November 10, 2005, 19:42
dila
Thanks Mr. Anton, I will try again
Old   November 10, 2005, 22:20
dila
Dar Mr Anton
I folowed your suggestion and I got it, but then when I start to analyse the STAR, there is a massage comes from the star launch such as:
PNP: Analyzing User coding in "ufile" directory. PNP: compiling /d//bin/f77 -O2 -f -v -N3 -N26 -N25 -Q101 !Q19 -c uparm.f -o windows-x86-absoft_8.2a-dso/uparm.obj PNP: /C/PROGRA~1/CDADAP~1/STAR-CD/bin/star: /d//bin/f77: No such file or directory PNP: ***ERROR*** Compilation error in user file "ufile/uparm.f". PNP: ==> Please check the compilation error messages.
In my working directory, ufile directory was created and uparm.f file is also already there and I have edited instead.
Should I install absoft8.2a for windows version? My computer only has f77 fortran software. Or is there any other error should I fixed up?
Thanks
Old   November 11, 2005, 08:41
Jamie
The Absoft Fortran compiler is the only one you can use. Please read the installation notes.
Old   November 11, 2005, 09:37
Anton S. Lyaskin
And why do you need user subroutines for tutorial 11? Your grid change goes through cgrid.cgrd, so you don't need anything else. Moreover, if you use Star-CD v.3.2 or higher you have to delete 'ufile' folder if you don't use user subroutines - unless you'll not be able to start the simulation
Old   November 14, 2005, 01:40
sandianzi
i want to see it
Old   November 14, 2005, 01:48
DILA
Dear Anton
You are right I dont have to use uparm subroutine, and can run the star. But, another problem arises during simulation:
I--------------------------------------------------| CALCULATION MONITORING INFORMATION |-------------------------------------------I
TIME I------------------- GLOBAL RATE OF CHANGE -----------------I I------------ FIELD VALUES AT MONITORING LOCATION---------I
STEP UVEL VVEL WVEL MASS T EN DISS ENTH U V W P TE ED T
*** ERROR #096 *** CELL 589 HAS ZERO VOLUME AND IS NOT A DELETED CELL
*** ERROR #096 *** CELL 590 HAS ZERO VOLUME AND IS NOT A DELETED CELL
*** ERROR #096 *** CELL 591 HAS ZERO VOLUME AND IS NOT A DELETED CELL
*** ERROR #096 *** CELL 592 HAS ZERO VOLUME AND IS NOT A DELETED CELL
etc...
and also
sed: -e expression #2, char 10: Unterminated `s' command sed: -e expression #2, char 10: Unterminated `s' command
I will check again, whether I made any typing mistake. .
Thanks.
Cannot create cavityfoam in FoamX Tutorial 21 airfoil OpenFOAM Pre-Processing 0 January 19, 2008 10:55
How to create a .erd file? mehul Siemens 2 November 26, 2007 19:52
Star_cd 4.02 moving mesh using cgrid.cgrd IGG Siemens 0 June 29, 2007 12:10
how to create cgrid.cgrd file kathir Siemens 11 March 1, 2006 01:02
cgrd file Tushar Kanikdale Siemens 1 June 12, 2005 17:57
