Field data
Old   November 29, 2005, 00:10
Default Field data
Jorge
I am new user of Star-cd 3.22, modeling a bank tube with a trimmed mesh of 28417 cells, using high reynolds model with a Re=25000, at boundary condition i am using inlet and pressure at aoutlet. The problem i have is after solution converged, the velocity U,Vmag getting from post register is cero in most of the vertices alined through the tubes. Any help should be appreciated.
Old   November 29, 2005, 11:31
Default Re: Field data
Ben
If you want vertex data you need to user caver first, at the moment it sounds like you havent done this so you are trying to look at vertex data when there is non....on another note if you are modelling plane channel flow with that low cell count, I would'nt use trimmed cells. Just create hexas using vc3d or blocks.
External magnetic field data Richard Lee FLUENT 7 January 11, 2019 04:43
may i import flow field data to do particle track? Hao FLUENT 8 April 29, 2008 08:22
plotting field data thomas Siemens 5 November 16, 2006 18:09
Putting submesh field values into field on parent mesh helmut OpenFOAM Running, Solving & CFD 2 June 20, 2006 07:31
field by field decomposition vs. component-wise zhanglei Main CFD Forum 0 January 5, 2001 09:06
