How to save cell set post data in to a file
Old   January 26, 2006, 05:56
Default How to save cell set post data in to a file
Negin
Hi, I am trying to save the post data for a cell set which is a small part of the whole cells. When I try to save it from the post registers by the operate function, the post data for all of the cells are written to the codded file, so far I have not been able to find a way to write the data for cell set only. Could someone who knows a way, help me? Thanks alot in advance
Old   January 27, 2006, 03:41
Default Re: How to save cell set post data in to a file
Alexandre
Hello Negin,
The best way to export post data of a cell set is to use the command SAVU. In the post register, load the data you want to export (cell centroid coordiantes, velocity mag, pressure, TKE...) and execute the foolowing command: to export values stored in the post register 1 to 4 in a text formatted file named data.usr SAVU,data.usr,BOTH,CODED,CSET
that's all
AJ
How to save data file in ascii after each iteratio jay FLUENT 13 December 18, 2017 15:42
Smallest binary file format to save large data Zonexo Main CFD Forum 2 June 2, 2008 20:25
How can i get cell data into txt file? Steve Siemens 8 July 22, 2007 14:41
save data file UDF lichun Dong FLUENT 0 August 18, 2005 17:47
about export data file in cfx-post lingo CFX 0 October 30, 2004 08:48
