memory management under unix system
Old   March 21, 2005, 04:57
Default memory management under unix system
nicolas
I have an important problem with management of memory under unix os (kernel : 2.4.18-6mdkenterprise). I would like to submit a job using 2 Go of ram. We have a quadriprocessor with 4 Go of ram. But the os seems to divide the total memory ressources by the number of processors (impossible to run a job exceeding 1 Go of ram). Can you give me some advice concerning modifications of our system os in order to allow large computation (without pro-hpc license).
Cordially yours.
Old   March 21, 2005, 09:17
Default Re: memory management under unix system
Jörn Beilke
Either you switch to a 64bit platform or you run the case in parallel.
Old   March 21, 2005, 12:38
nicolas
There is no other way to allocate the total amount of memory to a single processor?
Old   March 22, 2005, 04:36
4xF
My guess is that this is set by kernel parameters, for which a given amount of mem is set per processor. Can you check that?
Old   March 22, 2005, 12:00
nicolas
High memory is activated, but submission of large simulation (executable of 2 Go) is still impossible (segmentation fault). Have you please some advice about kernel parameter in order to allow my computation ?
Old   March 22, 2005, 12:58
4xF
BTW, which version of the code are you using and with which kind of operating system? Is it by chance Linux and v3.150A?
Old   March 22, 2005, 13:04
nicolas
I used linux with release v3.150A. I hope that you have the solution or informations about configuration of pro hpc on multi proc linux server.
Thancks by advance
Old   March 22, 2005, 13:32
4xF
Then the reason is why you cannot run a simulation requiring more than 1 GB of memory comes from the dynamic linking of libraries. Solution: You need to compile a static executable with the additional compile option -Y, hence from the command line: star -Y -snf star-star.exe instead of the default options: star -svf star-star.exe
Note that star-star.exe is the default executable name. For getting all the starlink options => starlink -h
Enjoy... ;-)
Old   March 23, 2005, 04:43
nicolas
Always trouble with compilation. Y option do not appears in my compilator options (Absoft fortran 77 compiler 5.0). In your previous message you recommand to use : star -Y -snf star.exe star is not a valid command (you may be think to starlink ??).
Actually i'm looking to used prohpc, but i have some trouble with mpich environment setup but i keep faith
Help is welcome
Old   March 23, 2005, 05:47
Jörn Beilke
Iy you want to use between 1GB and 2GB with your version you have to add the -Y switch when doing the starlink.
> starlink -Y .....
Old   March 23, 2005, 08:50
  #11
4xF
First, I apologize. You should have read starlink instead of star (that happens when you write it at late hours...). Anyway, for parallel runs, please install the mpich libraries the STAR-CD support office should have provided you with (latest version is 1.2.4 to my best knowledge). If they are already installed, check the environment variables MPI_ROOT, MPI_DEVICE and MPI_ARCH. Adding $MPI_ROOT/$MPI_ARCH/$MPI_DEVICE/bin to you $PATH should allow you to find mpirun. That's something to start with... For additional details, please read the installation guide...
Hope this helps you further.
Old   April 5, 2005, 03:16
  #12
ali
respected sir i m looking for hte detail of the topic according to the operating system point of view your positive action in this regard will be highly appriciated
Old   April 7, 2005, 03:32
  #13
omair aamir
i need the complete documentation and code if provided please consider my request thanking you
Old   April 21, 2005, 08:51
  #14
Gustav W
please send me the notes
Old   July 2, 2005, 16:47
  #15
tallat
i want details of this topic
Old   August 3, 2005, 13:52
  #16
kumar
mesg from mem.mang on unix
Old   October 7, 2005, 07:30
Default Re: memory management under unix system *NM*
  #17
satheeshkumar
Old   October 15, 2005, 08:19
  #18
girish gaurav
plz send me the the a breif detail about memory management in unix system. i will be greatfull to you. girish gaurav
Old   November 8, 2005, 05:06
  #19
sarvani kalagara
sir, can u please send me this article u have written on unix memory mangement as i need it for my project work..
thanking you
sarvani k
Old   December 28, 2005, 03:34
Default unix memory managment
  #20
iftikhar khan
send me notes
moving mesh in unix system? xhliu1 Siemens 0 November 9, 2006 18:07
Memory management incongruence Flavio CFX 5 November 1, 2006 12:18
how to define memory allocation factor in unix steven CFX 1 October 25, 2005 10:26
memory problems with a code on unix vince Main CFD Forum 2 November 5, 2002 03:48
memory management! Tingguang Ma Main CFD Forum 3 October 25, 2000 08:35
