Help on cyclic boundary!!!
Old   March 15, 2006, 11:37
Default Help on cyclic boundary!!!
Mehdi
In my problem in cylindrical geometry I have one cell in theta direction and I use cyclic boundaries. In normal grids this boundaries works but when I refine my grids, especially in Z direction I get errors in checking of cyclic boundaries. If you know the solution please help me. I'm thankful for your help in advance.
Mehdi,
Old   March 16, 2006, 06:39
Default Re: Help on cyclic boundary!!!
allan
try deleting all your cyclic matches: cyde all. Then rematch your cyclic boundary regions with cyma.
Look in prostar help for cyde and cyma.
allan
Old   March 16, 2006, 08:26
Mehdi
Thanks for your comment,
I did it but it doesn't work, after refinement and defining all boundaires, I can pass first checking for boundaries, but in the special check for cyclic boundaries, I get this error message for many of cells:
Two cyclic sets have identical masters, check if they have duplicate slaves or if they can be merged.
If you know, please help me more to solve it
Thanks, Mehdi
Old   March 16, 2006, 08:47
allan
try to put these boundaries into a set, it should do it if you get this error message when writing the geometry file.
check by plotting them
I don't know if there is a command that can merge duplicate cyclic pairs.. perhaps it's something like cymerge, you'll have to check prostar help.
If you have duplicate boundaries, they can be merged after they have been put in a set by:
bmer bset
you may have to redo your cyclic matches again
hope this helps
allan
Old   March 16, 2006, 11:26
Default Re: Help on cyclic boundaries(Error 87 and 88) !!!
Mehdi
Thank you very much, I'm beginner and I couldn't understand very good your points, but about merging and redo the cyclic boundaries I did it several times. Yet I couldnot solve it and I always get errors no. 87 and 88.
Old   March 16, 2006, 12:23
Tom
I put cyclic boundaries in the same category as cp match errors - works of the devil. One thing to be sure of is that you are using arbitrary rather than integral matches. To merge the boundaries try:
bset,newset,region,XX (where XX is the region number)
bmerge list
Now after saying that, I have never had it work for me. The problem is that if you use a custom mesh, it is quite possible that there is not a one to one match of the faces that you want the cyclis boundary. Therefore, using an arbitrary match is necessary. Also, it may be necessary to zoom in on the refined sections to assure that all of them are chosen in the selection. Sometimes a change in cell size stops the selection if you are using select based on edge angle.
I hope this helped some.
Tom
Cyclic Boundary Condition SG Siemens 0 June 1, 2008 14:56
Cyclic Boundary conditions johndeas OpenFOAM Running, Solving & CFD 1 January 4, 2008 20:34
cyclic boundary sijin james Siemens 3 May 15, 2007 12:07
Help!cyclic boundary Bard Siemens 0 December 16, 2006 06:41
Cyclic Boundary furkan Siemens 1 November 28, 2005 09:12
