Vaporization problem
Old   April 7, 2006, 17:27
Default Vaporization problem
sid
Hello all,
I want to model a water flow over a flat wall, a portion of this wall is heated at 1600K. So the water close to the heated region is going to vaporize. I am using the free-surface option and the VAPORIZATION module. My initial condition is that I have water(L) in the whole domain. I am interested in the steady state solution. For a 1m plate, at low speed (0.1m/s) I get the result I expect (thin water vapor layer). However when I increase the speed, even though I refine the mesh in the heated region, my solution diverges. This seems to be a simple problem to simulate but I can't get it figure out... Any help would be appreciate. Thank you
vaporization arman597 FLUENT 0 February 21, 2008 11:03
vaporization using DPM? surya FLUENT 2 September 12, 2007 03:24
Vaporization Phase? Jason FLUENT 0 March 4, 2007 22:01
vaporization Mrak FLUENT 0 February 20, 2007 11:41
DPM and vaporization Denis Vedrine FLUENT 0 April 18, 2000 05:31
