How to change the dimensions in STAR-CD?
Old   April 21, 2006, 09:30
Default How to change the dimensions in STAR-CD?
Particle
It defaults all dimensions in meters for the coordinates (x,y,z) in STAR-CD. How can I do in STAR-CD if I want to convert the dimensions into millimeters? What is the command in STAR-CD?
Old   April 21, 2006, 09:51
Default Re: How to change the dimensions in STAR-CD?
a student
Give command GEOM and see what it asks you to enter. In your case you need 0.001 as gscale.
Old   April 22, 2006, 01:31
rajesh
you can save the geometry file by using a scal factor of 0.001 and during run you can give the option in mm
Old   April 22, 2006, 06:32
Particle
Thanks. During run I can give the option in mm. Do you mean this command "star -mm -dp", -mm is the option?
Old   April 22, 2006, 06:51
autocat
vscale
Old   April 23, 2006, 10:16
TG
Type "star -h". It gives all the allowable options. There is no -mm listed. Type "star -mm". Its says mm is not a supported option. Do you read anything at all before diving in?
The actual data that star uses MUST be in meters. You can either scale your entire model to meters with the VSCALE command in prostar or when you write the geometry data out to STAR you can scale it then. Type HELP, GEOM or HELP, VSCALE.
Now really how to avoid the dimensions vitke OpenFOAM Running, Solving & CFD 8 August 30, 2007 07:58
Dimensions Gustavo CFX 0 December 19, 2006 12:33
can we change the dimensions in fluent Rashmi FLUENT 3 April 3, 2006 03:35
display - dimensions rookie FLUENT 2 June 25, 2003 21:28
SOURCE DIMENSIONS Andreas Abdon CFX 1 March 13, 2000 10:51
