How to deal with the user subroutine problem?
Old   May 11, 2006, 14:47
Default Re: How to deal with the user subroutine problem?
  #21
Jim
This logic doesn't work - the coding may not fail on its own, but if you remove the user-coding from STAR, no doubt it won't crash either.
A few points:
1. Are you sure it's the data statements - ie. have you removed all other coding from the routine and does it still crash?
2. you say that your data statements are very long. How many characters are there on any one line? Some compilers don't like long lines. Try the same code, but with a small array (e.g. array(1:2)). It's very unlikely that it's just that STAR "doesn't do data statements".
3. Try printing the array. You may find that some of it's OK, then it crashes halfway through printing the array. This would suggest that it's not being assigned correctly.
4. Go on a diplomacy course. There are a lot of people in this forum who have done a lot of very complex user-coding with STAR. The power of its user-coding is one of the reasons why it's the second most used CFD code in the world. Giving up and assuming it's a bug is the easy option, but generally not the right one.
Your test of compiling the code on its own is one approach, but not the definitive one. User-coding isn't the same as compiling a program on its own, for example STAR uses a whole host of compiler flags, and the routine is being called from a large and complex program. User-coding can be more demanding than writing a program on its own, because if you allocate an array incorrectly it can overright something that you kidda needed, whereas you can get away with it in a standalone program.
5. Good luck. Complex user-coding can be hard work, but remember that's because it's complex, not because user-coding in STAR is buggy. It isn't. As has already been said, you invariably end up making a change in your code rather than submitting a bug.
Old   May 19, 2006, 09:30
  #22
Richard
Particle - do you have any news for us about this problem?
Problem in using user subroutine of CFD-ACE+ 2007 weixi Main CFD Forum 1 January 13, 2011 20:58
User Subroutine Garryx Siemens 1 June 25, 2005 00:13
User subroutine problem Yuqing Feng CFX 0 May 5, 2004 23:39
User subroutine Don Baker Siemens 1 September 29, 2002 12:27
user subroutine problem John Siemens 2 September 4, 2002 08:46
